Ishould have asked can I put the new hose ends on a old hose. I have the connectors, just inconvenient sometimes.Shane Holland said:1951CorrectCraft said:Are the new hose ends compatible with the old hoses?
[member=24979]1951CorrectCraft[/member], compatible in what way? Like joining hoses together? If that's what you mean, you would need to use the method of changing the connectors and using a coupler, which has been the method used for the "old" hoses. The "new" hoses can be joined together without the need of a coupler.
1951CorrectCraft said:I should have asked can I put the new hose ends on a old hose. I have the connectors, just inconvenient sometimes.
Don T said:I assume that the Bluetooth remote module will not work on a CT22 & CT33?
carlswoodshop said:Thx for the link to my video. [laughing]
Claimdude said:I have the light grey 3.5m 27mm hose I use with my CT 22 for clean up on work bench etc. I have a new 5mm 27mm hose in my shopping cart at Toolnut but am a little hesitant that the increased length will reduce the suction too much. Again I use it to clean up shavings, etc only and it is never hook up to a tool. What really bugs me about the grey hose it the ribs hang as I pull it across the workbench. The CT 22 has the Ultimate Dust Deputy on it and boom arm, etc.
I was able to gain access to some information. The maximum length for combining D50 and D27 hoses is 98'. We would only recommend this length, or lengths beyond say 60' for fine dust like that produced by sanders.
Shane Holland said:I couldn't quickly find the video I thought I remembered seeing on hose length and its impact on suction. I'll keep looking. In the meantime, here are some threads on the topic.
http://festoolownersgroup.com/ask-f...0-mm-hose-without-loss-of-suction-efficiency/http://festoolownersgroup.com/festool-tools-accessories/maximum-hose-length/http://festoolownersgroup.com/festool-tools-accessories/ct-22-reach-possible/http://festoolownersgroup.com/festo...e-length-of-a-hose-for-a-ct22-dust-extractor/http://festoolownersgroup.com/festool-tools-accessories/maximum-hose-length/http://festoolownersgroup.com/festool-how-to/ct-133-hose-length/
And a quote that I made in that first thread based on specs from Festool when I was there.
Thebesciak said:I think I found the recipe:
Cheese said:Thebesciak said:I think I found the recipe:
The only problem is that the sleeving makes the hose a lot stiffer. I have 2 of them downstairs that I no longer use. One for a CT 22 and one for a MIDI.
ben_r_ said:Not sure if its been stated already or not, but can you have two remotes paired to a single vac? Might be nice to have multiple hoses with the remote on them.
Oh awesome! Thank Shane! Ill probably pick up another couple remotes just to have one on each hose!Shane Holland said:[member=58821]ben_r_[/member], up to five remote controls can be connected to one vac.ben_r_ said:Not sure if its been stated already or not, but can you have two remotes paired to a single vac? Might be nice to have multiple hoses with the remote on them.
