- Jan 22, 2007
I am now taking orders for the Multi-position Guide Stop (MGS-20) attachment for the Domino Tenon Joiner. You can read more about this, or place orders at www.dominoguide.com
The MGS-20 was formally announced 2 weeks ago at the Festool USA headquarters during the Cabinetmaking End-User Training class on November 2. It is an attachment for your Domino joiner that fits on the Domino base using the existing screw holes for the Support Bracket.
The MGS-20 gives you stop positions, similar to the built-in pins on your Domino, except these are fully adjustable, and you can use more than 1 pair (up to six positions per side). It fits both new and old style Domino bases, and you do not need to alter your Domino to use it.
The position stops (called dogs) flip forward when needed, and flip back, out of the way, when not needed. They are extremely rigid when engaged and will not deflect sideways when you push the workpiece against them. This is critical for maintaining accurate mortise positions.
A spacing/adjusting screw can be used on any Dog arm to reduce the distance between stops. With a spacing screw installed, you can have two adjacent stop positions be as close together as 1/16-inch. They can also be used for fine tuning the stop positions.
The MGS-20 comes with 2-pair of stop position assemblies, stainless steel thumbscrews for mounting to your Domino, and instruction manual. The outer pair of stop assemblies also include stainless steel socket head cap screws for the spacing/adjusting screws.
The MGS-20 is available now for the introductory price of $99 (US). www.dominoguide.com
(If you are a Festool dealer, I will provide you with login information to the dealer area of the website for ordering. Click the button at the bottom of the home page to contact me.)
