New Dust Extractor Ends
I have some of the newer tools and vacs with new "improved" hose end.  Any way Festool can offer the older style ends as well as the new one.  I'm personally not a fan of the newer ends and don't see it as an improvement. The ends has voids and when disconnecting the tool from the hose it is messy and drops dust on the floor.  Now I have to turn on my vac before disconnecting a tool. [member=57769]TylerC[/member]
I wouldn't expect to see a the old one come back, but I've passed this feedback along to our NA product management team. Out of curiosity, how much dust are you getting on the floor from this?
Same problem here.
It is the amount that is packed in the voids. About 1/4th teaspoon.
It does seem like Festool fixed a problem that didn't really exist.  My old style hoses only very occasionally slip off the TS saw - they practically never come off my sander, router, jigsaw. . .
I've noticed more complaints about dust gathering in the new connector grooves than I ever noticed about the old connector slipping off tools.
Like said in another post, about a 1/4 teaspoon.  The dust builds up in the voids and falls off the hose end when the tool is removed.  I never had an issue with the older style.  Festool might have over engineered this part.  Please let us know if you find out anything.
I am not a fan of the new ends either but if they are to be judged then it needs to be as a matched set at the end of the hose. With the bayonet connector on the hose as well as the tool I would imagine that the dust trapping would be much less. Festool set about the introduction in a quite reasonable way by providing some of the new hose ends with some of the tools (not sure if this was a one off or if is still happening).
I too have never had any issue with the old design ever coming off a tool but that design did require a little effort to get it firmly into place.
If Festool were to "solve" any hose issue with their TS saws then in my view it would be to stop the hose receptor on the TS from turning once it is set in the position that you want. Most of the time I want the receptor to be pointing up as much as it can. It is a real pain for it to then flop over and allow the hose to drag across the work surface.
I'm finding the new hose end does not stay connected to the stainless floor sweep pipe or the other cleaning tools.  The old one would let me hold the pipe while picking up dust across the floor, or with a brush along baseboards.  This new one requires my hand be on the hose to keep it connected.
On the plastic hand tools like the brush or crevice tool, this new design does not give a tight seal.  Instead of all the suction going to picking up dust, there is now leakage as the new end does not seat fully in the tool opening.
And these are Festool cleaning tools, not third party.
[member=57769]TylerC[/member] suggest you try it on cleaning tools there and report back if you experience the same thing.
I would have thought you already knew about the "ratcheting" dust port for the TS55/TS75 that can utilize the new bayonet hose fitting. It is required when using the newer dust bag too and can be bought as a kit or separately. Supposedly there is only one direction it will fit into the systainer without removal. I have yet to get one myself and fully understand your complaint. The part is on my short list.
Festool seems to offer two part numbers?? 202096 or 10015824
https://www.ffx.co.uk/tools/product...Piece-To-Connect-Chip-Collection-Bag-To-Tsc55
[member=57769]TylerC[/member] - please tell them the peanut gallery members that aren't painters aren't really satisfied with improvement R&D has dreamt up - and that the old style needs to be CONTINUED TO BE MANUFACTURED for some time to come.  I can't say this strongly enough !
Mgmt. is ,in effect, penalizing early customers with an inferior product in the hopes of chasing a new segment.
I'll bet you don't even have plans in the works to update things like the vac tubes/handles do you?
And .......I'd like to know why none of this was uncovered during the research / prototype phase.  Peter H. insists that you test product before launch but that doesn't seem to be the case.  I uncovered this leaking issue on several tools withing minutes of using the new hose end , and my experience doesn't seem to be operator error or an aberration now that some others are actually starting to use these things.
So either you don't test, or you solicit the wrong folks for testing. Or, you do test, find problems and management decides the punters will just have to live with the issues ???
None of these bodes well for a company trying to stay at the top of a competitive market.
[member=50292]Peter_C[/member] ...can you or anyone else confirm that this ratcheting dust bag attachment you've posted will accept the 27mm extractor hose?? I'll def grab one if so... Will stop me having to tape my current one into position.
Cheers
Cheers
[member=22067]mrB[/member] yes the 27mm hose fits snugly inside the newish ratcheting attachment.
Peter_C said:
I would have thought you already knew about the "ratcheting" dust port for the TS55/TS75 ....
I got one of these for my TS75.  It is an improvement on the original, but not perfect - the "ratchet" is pretty weak so that the hose direction does click around when you don't want it to.
Cheers
Regrettably the dust trapping/spillage problem is not better when using matched ends - see the thread linked to earlier with some photos.http://festoolownersgroup.com/festo...ing-dust-fitting-leaking/msg494576/#msg494576
Moreover, the hose needs to be used with new and old style Festool tools and, yes, third party tools too:-o
Others have commented on the R&D process failure on this issue and I agree.  Having been a longtime evangelist for everything Festool, in particular the idea that clean, dust-free working was in the Festool DNA, this issue has significantly clouded my devotion - unfortunately, I am reminded of this every time I use the new connector.
It is a reasonable test of Festool to see what they do about it and how quickly.  We are where we are, so what would I propose?  Festool should recognise this problem - it should withdraw the new hose end connector style in favour of the old one or maybe (to save face) a newer version of the old style - it should offer a no-charge swap - it should reengineer the dust extractor ports on the new tools and revert to old style ports on older tools (if any have been changed) - it should offer a no-charge swap replacement of the port on tools bought new.
[There should then be an internal enquiry into how the engineering dept was allowed to do this and a thank you to the customer base for providing all this unpaid advice and expertise!]
We can hope.
Cheers
Agree completely with this proposal. I've not had this problem yet, as I've not bought anything big for a while. Trouble is I'm waiting for new stock of a domino to arrive-will it have the new fitting. Same with the sander  which I've just ordered. If my dust extractor is the old fitting and has no issues, I don't want to buy a problem. I'll have to see with the sander. If it is a problem I'll review the purchase of the domino until the issues are resolved.
[/quote]
Hi Peter
Thank you for pointing this out. I am in the process of fitting one and will include the detail in an upcoming "Workshop Notes" video. It seems to be stiffer to move than the standard fitting so fingers crossed.
I am new to Festool within the last 8 months. I had purchased a used ETS 150/3 and then the Pro 5. I can honestly say that I detest the new locking hose end. There is always dust left in the end that fall out when the hose is removed. I rarely ever lock the hose end on since it is such a pain and requires way too much effort.
I much prefer the old style friction fit. I don't see how the hose could fall off if it was pushed on all the way. Unless the hose gets snagged on something and the tool was being pulled away.
I want the old hose end for my tools.
I've gotten a few tools with the new locking dust port.
It was generous of Festool to include the new hose end
with them.  However, they're shuffled off into a drawer.
They're not hard to figure out or anything, they just take
five times as long to connect and disconnect.
Bottom line, it seems like nobody likes them.
mattbar1 said:
Same problem here.
I have the older style on my sanders except the new Pro5 (which is harder to control than my rotex) and it does drop dust unless the vacuum is on when disconnecting.  1/4 tsp is not much unless of coarse you are sanding lead paint.  The new sanders and CT extractor hoses with new style comnector may have a problem passing certification.
It may not be an issue for me as I am deciding between sending it back for repairs or return within 30 days for refund.  6 months waiting for shipment for a defective sander.
Yes this is the festool equivalent of the "new coke" (not sure if the folks across the pond were subjected to that abomination back in the 80's or not)
Some nitwit in a cubicle somewhere comes up with a brilliant plan to fix something that isn't broken and makes things way worse as a result.
Coke was smart enough to admit their failure and reverse course...Will festool do the same and bring back the old style fittings? I have my doubts.
