CrazyLarry said:It was (at least in my case and at least 2 others I know of) caused by the t-loc systainers placing pressure at the weakest spots.
Having been sent a replacement from FT (no quibles), I cut a couple of pieces of wood to support under where the systainers rest and have had no problems since. I've clearly not been kid gloved with it because there are lots of scuff marks at the pressure points but no cracks.
This is a CT26
Locks14 said:CrazyLarry said:It was (at least in my case and at least 2 others I know of) caused by the t-loc systainers placing pressure at the weakest spots.
This is a CT26
This is really useful information! So essentially, although there is still an inherent design fault with the garage plastic, if I don't dock any systainers on top of the machine it should be ok.
Locks14 said:In the market for a new dust extractor as my old Bosch is on its last legs and considering the CT26. . I was just wondering if Festoool ever addressed and changed the plastic of the hose garage after all the complaints of it cracking and breaking?
Holmz said:Locks14 said:In the market for a new dust extractor as my old Bosch is on its last legs and considering the CT26. . I was just wondering if Festoool ever addressed and changed the plastic of the hose garage after all the complaints of it cracking and breaking?
What defines "its last legs"?
Is it running out of suction?
Holmz said:Maybe it needs brushes or some other help?
I had to send in my CT26, but it seems to be running fine now.
Unless you are using the docking or the boom, then I am not sure what the advantage is with a CT26. At that point it is basically a vacuum, so quantitative vacuum specs might dominate over the qualitative "System".
It sounded like the T-Locs create stress, but I am not sure about the classic systainers ??
I like the idea of the dock, but I wind my hose and cord into the space, and I do not have a boom arm.
There were some specs I saw the other day that rated CFM...
(Found it)
http://mafellusersforum.com/attachment/download/1502
Locks14 said:Holmz said:Maybe it needs brushes or some other help?
(Found it)
It might be brushes or something else repairable, but it's a small machine that since purchasing is getting a lot more use as my number of tools with built in extraction has increased in recent years. So I'm welcoming the excuse to change it for something bigger.
Maybe I'll just go for a bigge Bosch, the specs of the Bosch appear to show they move more air and have stronger suction than the Festool. I also have some Bosch tools in L boxx's so that's also a consideration.
Locks14 said:I also have some Bosch tools in L boxx's so that's also a consideration.
Holmz said:[member=14551]Linbro[/member] ,
Where did you get it? Locally or posted in?
