New Festool items on EBay UK
Woodchippie
I've spotted the new syslite duo Plus on EBay @ £299, for delivery in September.
Also some new systainers if anyone's interested.
FESTOOL 769965 SYSLITE DUO PLUS IN SYS 3 T-LOC 240V
***Pre-Order for Delivery Early-Mid September 2015***
Strengths and benefits
Unique LED configuration for 180° scattering angle and homogeneous illumination
High illuminating power (8000 lm) for brilliant lighting of a large surface area
Daylight-like colour (5000 K)
Sturdy and durable with 10,000-hour lifetime (L70) and shock-proof corners
Dust and water-resistant, withstands drops and impact (safety class IP 55)
Main applications
Safe handling: All contact surfaces heat up to 90 °C maximum
Practical: 4.8 m cable length for a large operating range, neatly stowed away in the cord holder
Flexible application range: Stands alone on the floor or on flat surfaces, attaches to the Festool tripod or hangs on hooks using the suspension on the rear side of the SYSLITE DUO
Safe to carry using the sturdy one-hand grip
Perfect in combination with the ST DUO 200 tripod, which is extendible up to 2.00 m – for the ideal position of light and illumination of space
Quick to assemble, extremely sturdy and very stable
Specification:
Illuminating power 8000 lm
Colour 5000 K
LED service life (L70) 10000 h
Colour rendering index, Ra 80
Housing safety class IP 55
Safety class 1
Cable length 4,8 m
weight 3,4 kg
[attachimg=4]Pictures
Guys I have seen this light and it's amazing I know it's a lot of money but it works out the same as two sys lights
SYS-Combi 2 is a SYS 2 with one drawer underneath
SYS-Combi 3 is a SYS 3 with one drawer underneath
SYS 4 TL-SORT/3 with three even height drawers
Tyler Ernsberger said:
Any idea when we will get them in the states?
As they are only plastic boxes, one would have thought there isn't too many hoops to jump through. so I could see no reason why they wouldn't be available in NA before Christmas.
[/quote]
[/quote]
Christmas of what year?  [unsure]
Please Welcome, The HK85
High-torque 2300 W motor with power electronics ensures constant power when sawing
Safe and easy handling thanks to the cutting depth adjustment with plunge function, pendulum hood remote control and guide wedge
Angle adjustment with central clamping mechanism from 0 to 60 degrees
Using the conversion kit accessories, the portable circular saw can become a groove cutter
In conjunction with the trimming rail, fast, accurate and mobile cross cuts
Safe and perfectly straight sawing along the guide rail
Main applications
Rip and cross cuts in materials up to 85 mm thick
Wide application range for mitre cuts up to 60°
Cutting tenons, square timber and boards
Cutting panel materials, wood fibre insulating materials and sandwich panels
Specification
Delivery Contents
Power consumption 2300 W
Idle engine speed 1500-3300 min ¹
Saw blade diameter 230 mm
Angular range 0-60 °
Cutting depth 0°/90° 0-85 mm
Cutting depth at 45 degrees/60 degrees 62/47 mm
Connection Ø d/e 27/36 mm
weight 7,0 kg
(Edit: Add Second image and info)
I guess they will now phase out the sortainers they currently sell? (ones without T-Loc)
Just bought 4 of them.
Nothing wrong with that , you may want them for the additional drawer sizes.
well 3 of them are for the wife :)
She got s sys-roll, sortainers and some systainers to keep all her craft stuff in  [big grin] [big grin] [big grin]
Always good to get the wife onboard with pricey festool stuff  [cool]
As the ETS 150/3 is on my wishlist, and it comes in a sys 3...I wonder if there will be an option to get it in the combi sys 3 variant. Would be handy to have sandpaper close-by. I really don't want to bother with a separate systainer with sandpaper.
elfick said:
I want a sys-combi with attic lid for my drills and carvex. :)
The attic lid would make better use if he waisted top 2 inches of the Sys-combi [wink]
Nooooooooo i am trying to make my stacks smaller not bigger well rant over i want the sys 4 lol
