tjbnwi
- May 12, 2008
Tim,
The Triton is a "low" pressure unit. The pump is 1:1, max inlet pressure is 100 psi.
I run the pump at about 40 psi the regulate that down to 15 psi with a secondary regulator. The air cap pressure in set at 20 psi at the pump, adjusted down at the gun.
The gun has, air fluid and fan adjustments.
Back in about 2 hours, Indy 500 about to start.
