Fuji Pressure Pot & Hoses
jyarbrou
Hi all. I have a Fuji MM4, and I have some larger spraying projects coming up where I don't want to have to refill the 3m cup over and over again. I'm looking to pull the trigger on the Fuji 2.5 Gallon Pressure Pot.
First, anyone with experience with this pot? The CAT and the Fuji are roughly the same price.
Second, what fluid hoses are you using? The Fuji hoses come as a set of both air and fluid, I don't need the air hose as I'll be using the turbine for the air. Any other brand of hoses recommended? Size preference between 3/8 and 1/4 ID?
Thanks!
I have the Quality 2.5 gallon. If you go with this you’ll need the single regulator unit.
Atomizing air is supplied by the turbine, you will need a small compressor to pressurize the pot. I believe the hose I use came with the pot, 3/8" if I recall correctly.
I place the product in a 1 gallon can, place it in the pot most times. It saves clean up. The entire system is very easy to clean.
Pressure pots work most conveniently with the T-70 or other bottom feed guns.
https://homesteadfinishingproducts....hvlp-spray-equipment/qualspray-pressure-pots/
