leakyroof
- Mar 23, 2011
Turns out I have 2 K4's and the new K5. Almost 1/2" difference in height Seth. K5 is a touch below 1 1/2" and the older k4's are just under 1" on the main work area sections of each jig.SRSemenza said:I usually eyeball them too. I am generally alternating screws with dominos and sometimes the screw placement matters for some other reason. I like to set a couple flip stops to left and right sides just to make sure the screws end up in the right spot when it matters on a bunch of pieces that are the same. Not a big deal though.
Is the base height of the K5 the same as the K3 (older front handle)? If so I could use my same set up and just swap out the jig.
