just spotted a new ledlight that i havent seen before? and also a new 6,2 ah AS battery [big grin] i wonder what more Festool will release this spring? [smile]
SRSemenza said:On the battery list I see a compact 3.1 18v. Will that run the TSC55?
six-point socket II said:Hi!
Could you maybe post a link to the PDF? you posted the screen-caps of?
I guess with the 6.2 Ah AS Batteries run time of the TSC 55 will be downright mind blowing. I too would like to know if the 3.1 Ah batteries can be used with the TSC.
And I sure would love to know more about the new LED light [big grin] [big grin]
Kind regards,
Oliver
Kind of makes sense given how most saws gobble battery power if used a fair amount.Phil Beckley said:SRSemenza said:On the battery list I see a compact 3.1 18v. Will that run the TSC55?
Hi
....nope the 3.1aH will not run the TSC or the HKC......but all other 18v it will and makes a huge difference to the handling and charge time.
RG
Phil
Summerson said:I love the new 3,1 Ah battery, good work Festool. Every tool have become much more well balanced, and of course lighter. The rubber covering also keeps the T 18 and BHC 18 more steady when you put them down, and looks better.
The whole Airstream idea feels like a complete fail. There's a reason computers are becoming fanless, and lighter. Who wants to listen to that? Who needs to charge that fast? I had an Airstream charger for 10 seconds, then passed it on to electronics heaven.
Btw, hello my Festool friends!![]()
Hi
RG
Phil
Summerson said:Phil Beckley said:SRSemenza said:On the battery list I see a compact 3.1 18v. Will that run the TSC55?
Hi
RG
Phil
What happens if i put two 3,1 Ah batteries in a TSC 55 then? Will it not start at all? I've been thinking of getting the TSC 55, but I only use 3,1 Ah batteries and would very much like to keep it that way.
Summerson said:This is what happens when you try to start a TSC 55 with two new fully charged 3,1 Ah batteries. It just wont start at all. The Festool salesman warned me the batteries would probably run out quickly, but apparently had no idea these products does not work together.
Will have to get a clumsier battery and another TCL 6 then. No worries...
. And the plot thickens.... [poke]SRSemenza said:Summerson said:This is what happens when you try to start a TSC 55 with two new fully charged 3,1 Ah batteries. It just wont start at all. The Festool salesman warned me the batteries would probably run out quickly, but apparently had no idea these products does not work together.
Thanks for checking and confirming. I think that's odd. Must be something to do with battery tech. I will have to double check my 15v LiOn. Maybe I only thought they were 3.0.
Phil Beckley said:Hi
RG
Phil
