New Mobile Base for my Bandsaw
Stone Message
Magazine/Blog Author
Hi Everyone
I have just created a mobile base for my new bandsaw. The bandsaw will get its own videos at a later date.
I needed somewhere to store my nail guns and air staplers when not in use. I like to keep them air line connector up and I always put a few drops of oil in the air line connector as I put them away. So, I have created some special bins as part of the new mobile base.
I have also demonstrated another way to make drawers out of MDF without using the Domino or a Lamello. Thin saw kerfs and equally thin floating tenons (made on the new bandsaw) is my solution.
Here are the links:
Part 1:
Part 2:
Part 3:
Thanks for the video.  I really like the spring trick on the storage bins.
I was originally going to pivot the storage bins about 6 mm brass pegs about 12 mm in from the front and 12 mm up from the bottom of each bin. However, the dynamics would have required a large space under each bin and so I had to think of another idea.
30 years ago I bough a box of mixed springs and have slowly been using them for all sorts of things, including pressure relief valves for my cyclone.
Hello Peter
Nice stand, i am about to purchase a band saw and want something decent, its a business expense no not too worried about the cost.
How are you getting on with the BS11INV, is it s decent machine, what others did you consider?
regards
Dale
dalep said:
Hello Peter
regards
Dale
Hi Dale
I am not sure where you are based and so forgive me if this is unhelpful...
Regardless of any links I have to Axminster through the Parf Guide System, I always check what things they have to offer. Up to about 8 years ago the cheaper Axminster machines were just a bit too cheap and might be disappointing. I have discovered that they are now putting a lot more effort into product selection and are also getting more closely involved in product development and refinement - more of this later.
I had my trusty Elecktra Beckum for nearly 20 years and knew that I could sell it easily having checked out ebay. I started the thinking about a new bandsaw nearly 3 years ago. My late brother was a professional wood turner and also taught the subject. He had bought an Axminster industrial machine for making turning blanks - it was beautiful but too expensive for me. I then visited several professional woodworking friends and saw the old but classic machines that they had. So I looked at the second hand market but nothing seemed to be right and the decent machines were just too big for my workshop.
I have been visiting Axminster a lot during the 2 + year development of the Parf Guide System and they took me into their confidence and showed me the prototypes and discussed the development of the BS-11. They even sought my opinion which was very flattering as I really know so little about bandsaws other than using them and getting them adjusted right. Last year I saw the pre-production BS-11 machine and saw it in action.
If there is one key test to try with any bandsaw it is cutting thin veneers (2 - 4 mm say). My late brother's machine could produce perfect 4 mm slices up to 130 mm. I have seen the BS-11 pre-production machine cutting 3 mm veneers about 120 mm across. The secret is in the blade guides which have to be capable of fine adjustment and be man enough for the job. One professional friend has recently spent over £300 on sacrificial guides for his monster machine and he is still not happy.
Now imagine my reaction when after a Parf Guide System meeting the Axminster product development chap thanked me for my various (not very educated) suggestions for the BS-11 and said that a machine would be sent to me on a long loan. When the machine was delivered and the driver and I were getting it into the workshop I realised for the first time just how heavy the machine was. The crate had 75 Kg on the outside and I think that the machine itself is just under 70 Kg. The steel plate is far thicker than anything you would find on a lesser machine and this helps keep everything lined up once adjusted.
I think that the first reaction of anyone seeing the machine is to discount it as a serious bit of kit because of its size. When I pointed this out to Axminster 2 years ago they just nodded and said "...wait and see how it performs." I now know what they meant. Actually its capacity is not far off other very respectable machines that might not fit through my workshop door. When I analysed the capacity I needed I surprised myself. I do not do monster scroll cuts and I doubt whether I would tackle a veneer over 120 mm (the BS-11 goes up to 160 mm). So, I think this new machine will do the job needed by serious amateurs and professionals but without annexing so much real estate.
I have already produced, what I consider to be, perfect 2.5 mm veneers and will take it to the limit when I make the videos about the machine. I showed one to my professional friend and he said that the quality of cut and uniformity of thickness was superior to his monster machine.
I hope to have some videos out in about 5 weeks time.
Hello
Thanks for the detailed reply, I'm near bournemouth so Axminster is close by, I want a decent saw, beyond the initial setup and adjustment, i don't want to have to keep messing about with it to get decent cuts. I have not really considered a used item as new suits the business expense side of things .
I dont have the room for a fixed full height floor standing model so this might just do the job. Its also in stock for next day delivery!
I now need to make a stand...
Dale
dalep said:
Hello
Dale
Hi Dale
If you PM your email address to me I will send you the plans free of charge (that is not specially for you - all my plans are free of charge and available to everyone).
Peter Parfitt said:
Hi Dale
Can I have your car [member=11196]Peter Parfitt[/member] ?
[big grin] while you're in a giving mood [wink]
Kev said:
Peter Parfitt said:
Hi Dale
Hi Kev
It is my plans that are free but if I plan to buy another new car you can have that (the plan I mean)  [big grin]
