bnaboatbuilder
- Sep 5, 2013
Seeing the new sandpaper for the 6" Multi-Jetstream2 pads made my head scratch a little bit. That's a lot of holes and a lot less sandpaper. The price is the same. Less usable sandpaper surface will mean buying more sandpaper. Empty holes don't sand wood. I'm sure Yoda would say it better. Personally 100% dust extraction sounds like a load of bologna regardless. This is woodworking, no matter what, there will always be dust. The marketing department just needs to stop with that nonsense.
So I put some high resolution photos into Photoshop which has a feature of calculating areas. Here's what I came up with basic math.
The 6" standard Festool paper with 17 holes has 93.6% usable sandpaper on each disc.
The new 6" Multi-Jetstream2 sandpaper with 49 holes has only 87.3% usable sandpaper on each disc.
Klingspor sells both a 9 hole and 17 hole sandpaper for the Festool 6" sanders. Their 9 hole discs have 95.8% usable sanding surface.
Honestly I think Festool should have gone with smaller holes entirely at that quantity. It will certainly be an added cost to users no matter what in having to buy more sandpaper in the long run. Less grit, less sanding accomplished.
Festool 17 hole pattern left and 49 hole pattern right.
Another note worth saying is that the purpose of 6" sander over a 5" is greatly diminished when 49 holes and only 87.3% usable grit on a 6" disc gets compared to a 5" disc with only 8 holes. I think Festool erred here greatly.
At this juncture, I use Klingspor stearate discs mainly and Mirka Abranet secondary for my sanders. I've lost count but I have approx 10 powered sanders and 4 contoured block sanders. I'm more than happy with Klingspor on my 6" Rotex and Abranet on the 6" Ceros. Any netted sanding discs unfortunately tear far too easily at the edges. The Ceros loses smoothness with papered discs.
