- Jan 22, 2007
New tools and accessories are coming October 2019, all of which are available now for pre-order!
Also, just a reminder that the new Bluetooth-enabled CT MINI I and CT MIDI I dust extractors will begin shipping on August 1st.
The ultimate in versatility, the cordless VECTURO oscillating multi-tool combines limitless functionality with exceptional controllability — delivering precise results in the trickiest of places. With tool-less Plunge Base and Depth-Stop (sold separately or included with the VECTURO Set), the VECTURO oscillating multi-tool stands apart, delivering unbelievable control and precision. The StarlockMax tool holder makes it possible to change tools quickly without the need for additional equipment. Additionally, the brushless EC-TEC motor with vibration isolation ensures that work can progress at an ultra-rapid pace at the same consistently high level of comfort.
ORDER NOW
[attachimg=2]
The powerful AGC 18 cordless angle grinder is highly durable and built for the professional remodeler who needs reliable, versatile performance. With its enclosed brushless motor, protected electronics, and variable speed, the AGC 18 is built to last and perform in a broad variety of applications. This powerful grinder is extremely simple to use — with a keyless arbor and guard change, variable speed, and a unique battery position for cut-off operation.
ORDER NOW
[attachimg=3]
Limited Edition Centrotec Set
The MINI-SYSTAINER is ideal for storing small parts and hand-held tools neatly and securely during transportation.
Its key feature is the T-LOC, the central control element, enabling you to lock, open and connect with a single turn.
And thanks to its light weight and handle, it is easy to transport. And the transparent cover means that you have a view
of everything at all times.
New Centrotec Bit Sets
Available as a 6-piece or 12-piece set, these new Centrotec bits sets have Torx, Phillips and Square Drive bits. The 12-piece set also has Pozi Drive bits, as well as coming in a convenient compartment made to store in the attic lid of your drill Systainer.
All bits are also available individually.
ORDER NOW
[attachimg=4]
The KAPEX is the most advanced sliding compound miter saw in the market today — making cuts that rival the finest trim work. Light in weight and heavy in features, the KS 120 is the perfect saw for the workshop or the jobsite. Effective dust extraction, precise cuts, easy adjustments, and quality components are some of the features that should make this saw the number one choice of professional tradesmen.
What's new? The updated Kapex has integrated expandable extension tables, internal changes to the motor have been made to help increase service life, a locking dust port, and newly designed base with integrated MiterFast angle finder stowage location. Additionally, the new crown stops (203356) and crown support board (204536) are available (sold separately).
ORDER NOW
[attachimg=5]
For reliable sanding of completely filled level 4 or 5 surfaces; ensures a very high level of adaptability and an even sanding finish on soft ready-made fillers; processing dry wall filler, plaster, dispersion filler.
ORDER NOW
- 18V Cordless Brushless VECTURO Multi-Tool w/ StarlockMAX
- 18V Cordless Brushless AGC 18 4½" Grinder
- Limited Edition Centrotec Set in MINI Systainer
- Centrotec Bit Sets (6-Piece and 12-Piece)
- Centrotec Driver Bits
- Kapex KS 120 REB Miter Saw
- PLANEX Granat Soft Abrasives
ORDER NOW
[attachimg=2]
ORDER NOW
[attachimg=3]
ORDER NOW
[attachimg=4]
ORDER NOW
[attachimg=5]
ORDER NOW
