jonny round boy
- Jul 21, 2007
Got a nice project to do for an event management company. They supply equipment for corporate events, exhibitions, and they also do the big boat shows.
The company owner has had a couple of temporary bar/reception desks made from stainless steel. Here they are at a boat launch, the first one used as a reception desk:
[attachthumb=1]
And the second as a model stand, though it's got a banner on the front & you can't see much:
[attachthumb=2]
He's asked me to make a prototype of a wooden version. This will be used with the top off the stainless steel one, or with a new wooden top. The final dimensions need to match the stainless version.
It's going to be approx. 2000mm wide, 1100mm high, and just under 750mm deep. It's made from Balau decking - the same timber used for the decks at the boatshows (see my previous thread on identifying the timber - thanks to everyone who helped!).
Originally, the client wanted the front & sides to be solid, but I suggested framed panels to mirror the stainless version. That will also make it lighter. The centre panels are a semi-opaque 5mm perspex, and will be backlit.
Here's the SketchUp model, with the stainless top:
[attachthumb=3]
And the same with the timber top:
[attachthumb=4]
The centre panel on this is 20mm perspex, again frosted & lit from underneath.
For transportation, the 2 shelves will slide out, the top will lift off, and the sides are hinged to the front & fold behind it.
The frames are made from the deck boards, ripped down to 70mm on the outside, with the 2 centre stiles the full board width of 145mm. Here's a detail of the junction between the top rails & centre stiles, with the top not shown:
[attachthumb=5]
The mitred joints will need to be very strong, so I've used this project to finally buy a Domino. The boards are around 21mm thick, so I'm going to use 2x 8x50mm tennons in each joint.
So far all I've done is prepare some of the boards & cut some sample pieces; the main issue I've found is the quality of the timber. It's great for decking, but not so good for making furniture. The moisture content of the timber is relatively high, so the boards have been drying out a bit in the workshop. Quite a few have twisted or cupped, and there's some watermarks/staining on some of them too.
I also found that the sample pieces I cut are now innacurate - I cut them as soon as I got the timber, with the 45 degree mitres. They've since shrunk across the width, meaning that the 45 degree angles are now less than 45 degrees!
I'm starting the build tomorrow, so I'll post pictures & updates over the coming days!
[attachthumb=1]
[attachthumb=2]
[attachthumb=3]
[attachthumb=4]
[attachthumb=5]
