HighlandMarine
- Apr 21, 2023
Does anybody know when we’re getting these stateside?
They sure are taking their sweet time [emoji16]Systainer.Store said:Soon. I don't have exact dates to share, but I'm told we are close. Next couple months are my hopes. It may come in waves, again speculation, of Combis, Sort, Rack and MINI S. There is a fair bit to get launched.
Last week I finally got details on the ToolBag and launched presales for that. As soon as I get word I'll be sure to spread the news.
Of course [emoji1787]. I bet those steaks taste 20% better once you hit’em with that branding iron!woodferret said:Gotta get the BBQ systainer out first afterall... [embarassed]
Josef said:They sure are taking their sweet time [emoji16]
It was, and there are threads on this.deBox said:...
I assume this was/is also possible with the T-LOC Sortainers but obviously they only have the single drawer height, so you'd just be making a stack of six identical drawers instead of three.
deBox said:Secondly, because of the modular way these are assembled, it's theoretically possible to disassemble several Sortainer units, then combine them into a Super-Sortainer that eliminates one base component and one top component that otherwise take up space when you simply stack two units, as well as reorder the drawers.
mino said:It was, and there are threads on this.deBox said:...
mino said:What is not mentioned anywhere is that the 3 drawer modules from a T-Loc SORT/3 are 87.5*3 = 262,5 mm high. i.e. the same as a Combi 2, or 2.5 of the 105 mm height "units. That way a SORT/6 in the T-Loc variety is 5.5*105 mm high, i.e. exactly as high as a SYS V + a SYS II.
Basically, each drawer unit is exactly 5/6*105 = 87.5 mm high. This was clearly not accidental, TANOS just never productised it.
With SYS3 this height "system" is not there, but should be still useful for your use case. As long as you have a use case for a "SORT/1" for something, it does make sense.
PaulMarcel said:deBox said:Secondly, because of the modular way these are assembled, it's theoretically possible to disassemble several Sortainer units, then combine them into a Super-Sortainer that eliminates one base component and one top component that otherwise take up space when you simply stack two units, as well as reorder the drawers.
That would work really well for a stack of original classic Sortainers used for small parts and kits. I never separate them so losing the wasted space of inter-tier bottoms and tops would be interesting. This seems like something [member=1619]SRSemenza[/member] would latch onto.
PaulMarcel said:As for the first point, I can see a benefit to both the side-latch and tilt release mechanisms. Personally, in the shop, I'd prefer the tilt since it would make removing a drawer to take to the bench a one-handed fast affair. The side-latches would be better for things you never take out and never want to risk dropping, like photography things or rhinestones that would go everywhere.
I've come up with a retainer clip solution for this after having dropped the big drawer a couple times. It's a problem with the short drawers too, though not as pronounced. But, since the small drawers usually contain fasteners, I put retainer clips on all of them as well.Firstly, the drawers use a different retention system to prevent you yanking them completely out. On the previous T-LOC models they have a tab built into each side of the drawer that catches on the edge of the housing, and which you depress in order to remove it. I like this.
The SYS3 drawers, however, have two tabs protruding down from the 'ceiling' of the compartment that the drawer slides into, and catch on the rear edge of the drawer. To remove, you tilt the front of the drawer up maybe 10 degrees when it's extended, and it slides right out.
I actually don't like this new mechanism and prefer the side catches, but perhaps that didn't work as well with the taller style drawer or would have required two per side, compromising stability. But it does mean you need to be careful to keep the drawer level when you pull it out—to me it feels easy to pull up to far and release it completely.
