jonny round boy
- Jul 21, 2007
Saw some in the flesh this morning - the Sys4/Sort3, the Sys2Combi, and the Sys3Combi. I did, however, resist the urge to buy any, as at the moment I just don't have a use for them. I'll probably still get some anyway at some point...
BTW, the measurements for the individual sections are:
Top section 62mm;
Middle section(s) 87mm;
Bottom section 80mm.
Those are rounded up to the nearest mm (so if you add the heights for the Sys4/Sort3, it comes out at 316mm, whereas it's actually 315mm).
If (and it's a big 'if') you could get the sections apart, each additional drawer would add 87mm to the overall height, meaning that the resulting height wouldn't fit in with the systainer 'system', which is based on multiples of 105mm.
If you added a second drawer to, for example, a Sys3 combi, the result would be 315+87=402mm high. This is slightly (18mm) smaller than a Sys5 which is 420mm.
Top section 62mm;
