I've just started using my Conturo and have a question for experienced users.
I'm using .5 mm X 7/8 white oak edge banding and having trouble finding the sweet spot with regards to settings for heat, speed, and glue amount. I'm using the natural color pucks and as per a call to Festool applications, they told me to use the low setting for temperature. My main problem is I seem to have excess amounts of glue ending up on the feed roller. It peels off easily enough but is this normal? The guy at Festool told me the machine is far from plug and play which I realize. He also suggested the double feed method where you basically back up your strip of edge banding with another piece when feeding into the machine with the idea being that it will put more pressure on the glue head. I can't see any difference when I do this. So far I haven't used it hand held, only mounted in the conturo MFT. I'm sure I can eventually figure it out but any tips would be greatly appreciated. Thanks!!
