I'm looking to try and boil down some info on spraying and equipment....
Precursor: I've spent some time with Graco Airless sprayers, but absolutely zero time with conventional equipment.
Intended projects:
- Door package (20+ craftsmen style doors) arrive in ~2 wks. I have to spray them in our garage which is attached to the house. Side note - our gas furnace and water heater are in the same garage. From what I've gathered, assuming it is setup correctly, a HVLP minimize the mess, compared to an airless. I would likely be shooting something similar to SW Pro Industrial Water Born.
- Interior cabinets are on the honey-do list.
- Hobbyist wood working projects.
After lurking on this forum, I see a lot of people are very fond of the FUJI turbine systems. Based on your experiences, what makes them better or more desirable than a Graco or Titan? Or are they?
Assuming my research is correct, given that I'd like to shoot acrylics, it is suggested that I get at least a 4-stage unit. A 3-stage could squeak by, but 4+ stage is strongly recommended. Would you say that is a fair and accurate statement?
Another key feature that I'm looking for, is something with as low of a noise output as possible.
What style of a gun should I be looking at? Or does the gun type [preference] depend on the material used? I am impartial to a particular style aesthetically. I just want the best function for the $$$.
My local SW says they can get me into a Graco (FinishPro) or Titan 4 stage for around 850-900, which is considerably less than list price. Having said that, are there better deals that anyone is aware of? Should I be looking at any other brands?
Thanks!
Intended projects:
Thanks!
