New Woodpeckers OneTIME Dado Setup Fixture (US)
Shane Holland
Festool Dealer
The New Woodpeckers OneTIME Dado Setup Fixture (DSF) enables woodworkers to find the perfect dado stack combination before installing it in the table saw. When using the DSF along with the Woodpeckers clever Gap Gauge measuring device; dado setups are a "can't miss" operation. Check out the video, then order yours from The Tool Nut.
Order the Woodpecker OneTIME Dado Setup Fixture (DSF)
Very clever- The more I looked over the 'demo' pictures, the more I thought, geez, what do I have to lose with buying the combo set.  [cool]
bnaboatbuilder said:
One the thing I got from the video is whether we'll see Woodpecker dogs for Festool MFTs in the future. Seems like a possibility.
Woodpecker produced dogs from Delrin about 5 years ago, then they discontinued them. I purchased several.
J0hn said:
I just use the chart in the back of the manual for my Freud Dado Set, but to each his own
Example:http://www.freudtools.com/admin/manuals/Dado_Chipper_Chart.pdf
I have a 8" Freud set with similar arrangement. However, it's when you need to add a thin shim to your stack to match either undersized plywood or an odd ball dado that having this tool on a bench to precheck everything,  instead of loading up the arbor on the Saw, making a test cut, then pulling that shim out to swap a slightly different one... [mad], will make it worth it to me.... [big grin]
Bump. Order deadline is today.
