I have 2 pieces of 16mm piece of wood I want to join together with a Domino.
I am using a 8mm bit and set the height gauge to 16.
After cutting the slot I could see the slot was not centered? the top of the slot was only 2mm from the top and the bottom of the slot 8mm from the base.
What am I doing wrong?, or is it not possible to center a slot in 16mm wood?
