Salgonzalez said:So here is what I am looking at. Please let me know if there are things i can get away w/ not using or something i am missing.
Festool Domino 500 Systainer Assortment - 5 Cutters, 1255 Domino Tenons (498899)
$285.00
Festool TS 55 REQ Plunge Cut Circular Saw (561556)
Packages: Add a MFT/3 Set (+ $562.50)
$1,147.50
Festool LR 32 Hole Drilling Set in Systainer (584100)
$480.00
Festool OF 1010 EQ Router (574339)
Packages: Add a CT 26 (+ $535.50)
$945.50
Festool Quick Clamp, 6 5/8" (168 Mm) (491594)
$80.00 (qty 2)
Festool Domino DF 500 Q SET (574432)
$900.00
Festool Parallel Guide Set For Guide Rail System (P00108)
$325.00
Festool Clamping Elements for MFT Table, 2-pack (488030)
$105.00
Festool Kapex KS 120 Sliding Compound Miter Saw (561287)
Packages: Add a CT MINI TL (+ $391.50)
$1,766.50
Festool 3.5" Dual Mode Rotex Sander RO 90 FEQ (571823)
$395.00
Grand Total: $6,429.50
Does this sound about right for setup?
Wow! Fantastic set-up.
I would consider the OF 1400 for a router if you are getting only one. It is Festools most versitile router. You can use it with the LR-32 system(mounts to plate with provided screws) and their router tables if you think that is in your future. The 1010 will be easier for edge banding and mounts directly to the LR-32 plate though. I have the OF 1400 and love it.
Also a good square/ triangle will really help with setting up the MFT.
Steve Bace and Greg Paolini(SP?) have videos on how to calibrate the MFT fence.
http://www.woodpeck.com/carpentertriangles.html
This will work, but a bigger square makes calibrating easier:
http://www.woodpeck.com/1281.html
http://www.woodcraft.com/Product/2084579/37664/Woodpeckers-Precision-Woodworking-Square-12in-x-8in.aspx
