- Nov 24, 2011
I don't know about you guys, but one of the real beauties of my Festool gear on the finish side of things is the ability to work in the just about complete absence of dust. This profoundly affects how wood takes finish, and contributes to the rich depth that I want to see in my work.
However, there are times when certain sanding details just have to be done by hand. The original HSK set is great, but I always found it to be a bit of an oxymoron that after all of the clean power sanding, if I did a little final tweaking with a block just prior to finish application, I would be seeing what seemed to be significant surface dust.
Not so much anymore with the extractable HSK set.
