Holmz
- Oct 11, 2014
A few years ago a treated a room to reduce sound transmission.
The psychologist is moving office and needs a non-structural wall put up.
The floor is carpeted on a concrete slab, with brick side wall and an acoustic ceiling.
Thinking of putting base plate of 35-120 (2"x5") on he floor screwed down with concrete screws every 600-mm (2').
Then the side plates of 2x5 screwed to the brick in 3 or 4 places.
(Stuffing some open cell foam between the brick mortar gaps behind the vertical uprights.)
Q1> Does this sound proper?
Using 2x3-1/2 (35x90-mm) to hold each sides drywall with an air gap, so the uprights will be staggered between the inner and waiting room walls.
A door will go in between, which will be reused from the previous office. This has a falling seal that drop upon closure to seal the air gap under the floor, and worked well in the past.
I am thinking of scribe-transferring the brick/mortar patter onto a vertical "skirting board and cutting that with a jig saw to minimise the air gap on on the sides.
Q2> Does that sound reasonable?
I believe I have the rest of it worked out as far as dampners on windows and weather stripping on doors to help isolate the noise and sound. Most of the effectiveness was just sealing the power outlets and around the ceiling tiles to get rid of any air gaps.
Any general thoughts are welcome as I am not generally a wall installer, and it seems that all the local tradesmen are fully booked.
