If so, whether you're a new owner or not, get a spare dust shroud and "stache" it!
I have the regular dust shroud in the saw for most regular jobs, and I find the dust collection really good compared to other saws Ive used (Bosch and DeWalt). When I have a lot to cut or when the materials are MDF or particle boards, I mount the stache version.
Using the DD/shop vac, 36mm hose and auto switch, I decided to see the difference between the two shrouds in today's cuts (12" wide melamine). After 4 cuts per shroud:
Stache shroud - dust 3 image - less dust on the station (either side, though the photo shows only the dust on the right side), more behind the shroud
Standard shroud - dust 4 image - less behind the shroud, but far more on the station (either side).
What the images don't show is the amount of dust spilling on to the ground behind the saw station: Tons more when the standard shroud was used compared to the stache shroud. And that tells how effective the addition of the stache to the shroud is in trapping dust.
