Novice Live Edge Coffee Cabinet
Chris Cianci
Here’s a cabinet I made w leftover cherry and birch ply, shop made mahogany edge band, i epoxied the crotch and live edge maple top A lot of this was firsts for me as I’m a newer woodworker
GoingMyWay said:
Awesome!
How did you attach the top?  Do you have a guesstimate on how heavy the cabinet is?
Since it’s maple I threaded ( not a thread insert) into the center of the slab (from underneath)I drilled over size holes through the top of the cabinet , on the outer sides and put in screws with washers so The slab can go through wood movement  I lift it by the plywood top and try not to pull on the slab. It’s well attached but I’d rather not risk loosening it. I suspect it weighs less than 30 lbs
Thank you all for your kind comments
Hey Chris
How have you been doing?  I like the cabinet. Is this in your office? Next time we are on the way over to the beach in DE, I will stop by for a coffee.  [big grin]
