No draw runners either. Or draw stops so you can end up with the draw dropping on your feet [eek]. Considering the price point they are fairly well assembled with dovetailed draw fronts although the fit isn't great. Look like they have been cut with a bit that has seen better days. Joiner is correct on the "solid wood" being what I would call composite board. Hundreds of small pieces jointed together are very stable however which helps.
