OBSOLETE - Use Shortcut feature on iPhone to post photos directly from iPhone to FOG
jonnyrocket
Northwest USA
I’ve seen several comments here on FOG talking about moving iPhone pictures from their phones to a computer to convert and resize them in order to post them here on the FOG. There is an easier way, but it does take a little time to create.
Through the “Shortcuts” App, you can create a one step automation to do this for you. See this screenshot below to see how this is done.
If any are interested, I can do a step-by-step writeup of creating and using this shortcut.
Edit: typos corrected.
I use Imgur, a image hosting app.  Getting the images posted has been easy enough.  I have not managed to resize the images.  But I don’t spend that much time on these things, so not bothersome.
Michael Kellough said:
I’d like to know how to customize the convert photos shortcut like you have Jonny.
I have used it in the most basic way and sometimes the resulting jpegs are still too large.
In the 'Convert Photos to JPEG', tap the > and reduce the quality. You can go pretty low before it's noticeable. Just modify it by stepping down a bit and convert what failed previously to see where the sweet spot is
[member=297]Michael Kellough[/member] I think the “resize” step is what you are looking for. As I have it in my example, this limits any photo to the correct size for FOG posts.  It will force whichever is the longer side of the photo to a max of 1024 pixels. The short side gets reduced proportionally.
