HowardH
- Jan 23, 2007
i am going to route some dados using the 1010 with an 18mm straight bit. If the plywood doesn't quite fit into the dado, what's the best way to adjust for a precise fit? That router used to have an accessory, the Of-WA I think, which was a micro adjuster that worked on the old model but it's no longer listed on the Festoolusa website. What's the best practice for this operation using the router? I also have a 1400 but it's mounted in my CMS table so I don't want to remove it if I don't have to.
