joiner1970
- Jun 13, 2007
i used my of 1010 router today, nearly new only used it twice , noticed a lot of vibration today. I was using a brand new biscuit cutting bit so swapped to an 18 mm straight cutter also new and there was still vibration. I checked the 8mm collet and it looked clean of any dust and doesnt look damaged. It was bad the other day i was using a template cutter and when it was running it felt like the bearing was grinding at the end of the cutter, but spinning the bearing with my hand i could feel it was fine.
Anyone else come across this ?
