HowardH
I recently picked up my OF 1400 router and just friday I got the guide rail attachment. What a great combo! Cuts dados and grooves perfectly, that is, If you use some clamps! I'm the middle of creating the Jointech router cabinet and it's going to be a primarily festool project. TS-55 to breakdown the ply, MFT 1080 to hold everything down. Router to cut the dados. Might even use the Domino to attach the face frame but that's another story. I thought I would save a bit of time (almost always a mistake) and use the short rail attached to the MFT to cut a dado across the plywood. I figured the pressure I put on the guide system would hold everything in place. Wrong. I looked down and saw the dado walking across the piece. oops. Learned a few lessons today. 1. always buy more stock than you need ( I did, thank goodness!
) 2. don't take shortcuts. Using that router to cut dados requires the hold down clamps to make sure the guide rail doesn't move when pushing the router down it's length. 3. think about what you are cutting. I love the center finding feature of the router. I meaured the distance away from the edge I needed and then since I was using a 3/4 bit, added 3/8ths to get a perfect center. Cut the dado and admired my work. Then started looking at it. Hmmmm. Something doesn't look right here. Oops again. Should have SUBTRACTED 3/8ths!
Yep, cut on the wrong side of the line. Oh well, gotta cut another piece tomorrow and start over. Learning curve strikes again! God I love this Festool stuff. Even making mistakes is fun! BTW, on a sad note, I was in the Jointech factory on Thursday and heard the owner had very recently passed away. The last time I was there he showed me the new design for a lead screw table saw fence system he was working on. Now it's on the back burner, maybe permanently. His son-in-law is taking over the biz. He was a nice man, former Incra engineer. Young, too. Only 67 or so .
