Of guide bushes
VW mick
Hi guys can anyone tell me the part in need to use a set of guide bushes on my routers I've got of 1010 and of1400
Was thinking of the ukj set from axminsters
I think these are the ones though I am not talking through experience. I am sure Axminster would be able to confirm.
I found the Festoy guide bushings made for the routers are the best >>> and only
For the OF1010 you need http://www.powertool-supplies.co.uk/469625-sleeve-of-1010-eq-usa.html and for the OF1400 you need http://www.powertool-supplies.co.uk/493566-copying-ring-of-1400-eq-usa.html
One is a little bit cheaper than the other!
I have both of these, and the UJK guide bush set, and they work very well together.
If you don't have one already, you may also want to consider the Centering Mandrel - this one works for 1/4" and 8mm collets http://www.powertool-supplies.co.uk/festool-centering-mandrel-zd-of-d-6-358.html
I have an of1010 and use the leigh guide bush plate adaptor ( 704 I think) which allows use of american style screw in bushes. I have a set by UJK from Axminster.
Ollie
