Hello,
I'm about to build 20 drawboxes. The front/backs/sides all need to have a 15mm groove routed in them, 12mm from the bottom edge to enable the 15mm draw-box base to sit. It's my first time building them.
Nearly all of the videos I've watched show people using table mounted routers with grooving bits to quickly pass through the material and generate the groove. Given the wood is resting against the table; and the router is in a fixed position; the groove spacing from the edge of the board is identical.?
I'm wondering two things:
- Are there any solutions (other than the CMS) for under-mounting the 1400? Are they recommended?
- If I was to use the OF1400 on a festool rail to route the grooves, can anyone suggest the best workflow, clamping approach? I've got 80 pieces to groove and will be working to tight tolerances. The workflows I can think of seem quite cumbersome.
I must admit, I'm more and more attracted to the idea of a table mounted router. While I was enough of a believer to buy the OF1400, I've not quite gelled with the use of the router on a rail; and I find that so much of what I'd like to be routing seems easier with a table setup. I'm sort of wondering if I'd be better selling my barely used OF1400 and investing a table-mount kit. The obvious downside for that is that I'm extremely limited for space; so for the time being; I'd probably have to go with one of those 'mini router table' kits, rather than something in a nice big bench.
Grateful for any thoughts!
