ccarrolladams
- Apr 14, 2010
The CT sold in the USA all only have a single power receptacle, grounded 20a/120v which can accept the more common 15a/120v male plugs. There is a function switch to select Auto start, which supplies current to the tool; Off, which does not supply current to the receptacle; Manual, which turns on the vac without supplying current to the receptacle.
As a consequence, in the USA if you want to use your CT as an extension cord, you will have the vac in action.
