James Metcalf
- Jan 22, 2007
To those who have ordered the Centrotec Bit Assortment there are two small boxes in the assortment. One has brad point bits, the other Phillips bits. At first inspection I thought them very hard to open, but noted a scissor symbol on the bottom of each case. There is a small tab that must be removed. The cases are then very easy to open. This would be easy to miss and I thought I would give a heads up. This is one well thought out set.
