Painting, finishing, and polishing process question
Aegwyn11
So my goal is to get a nice smooth, glossy finish. So I'm using Pratt and Lambert Red Seal glossy paint and rolling it on (I don't have spray equipment). What I've been doing is to roll a coat on, sand it smooth (220 grit Brilliant2), then roll another coat on, sand smooth, etc etc. This seems to be taking FOREVER to get complete coverage...by the time I sand each coat to smooth primer is always showing somewhere.
My plan was to sand it smooth, new coat, sand it smooth, new coat, etc until I get total coverage after sanding smooth. Once I get there, I was planning to work up through the grits to Platin2 4000grit, then if necessary go to rubbing and polishing compounds. Now that I've done a number of coats and still don't have complete coverage, I'm wondering about my process. Should I just be sanding 'mostly' smooth in  between coats, get a few coats built up, then try to sand perfectly smooth?
My two cents worth is to use 320 or 400 grit - lightly.  Generally I have found that it is worth while to get each coat fairly smooth.  Hand sanding is easier to control than a power sander.
HTH.
Joe Ewing
Las Cruces, NM
Try:
Roll a coat on.
Let dry.
Roll a coat on.
Let dry.
Roll a coat on.
Let dry.
Sand smooth.  What grit you use depends on the finish (how easily it sands) and the texture the surface starts at.  But 220 is pretty rough to start.  Most finishes sand very quickly and you should work on the finish (retarder, water, floetro, BLO, etc.) and your technique to get it to level as best as it will.
Recoat if necessary.
As long as you don't wait too long between coats, there is no need to sand between coats.  Almost all finishes will adhere well to themselves when reapplied to a fresh coat.  Worried that the finish will be even bumpier or uneven after 2, 3, 4 coats?  Get a decent length board.  Sand smooth and prime.  Lightly sand the primer smooth and reprime/resand if necessary.  Cut into 4 pieces.  Apply one coat to all 4.  Apply second coat to 3 of the 4.  Apply third coat to 2 of the 3...etc.
Look at the surface.  Feel the surface.  They're all the same for texture.  If anything, the boards with 2 or more coats might be slightly smoother than the single coat.
Same applies for clear coats.  If I'm apply clear to bare wood, I generally only sand after the first coat (mostly because I'm using waterbornes and want to remove the raised grain) and after the last (only for high gloss as spraying generally should leave a pretty durn good surface).  Of course, if I make a mistake while applying finish and get problems in the finish (a run or orange peel or such), I'll take care of those problems before applying more coats.
Nick,
I think to get some real help here we need more information:
1)  Are you using water based or oil based paint?
2)  What is the material you are painting?
3)  Which sander are you using?
I do not claim to be a finishing expert, but I think 220 grit might be too aggressive.  I agree with Joe that 320 or 400 would be a better choice.  I have a tendency to oversand so I have been sanding by hand using either one of those sanding sponges or nylon steel wool pads.  Steel wool would work also if the paint is oil based.
Remember that all you are trying to do is remove all those little nubs and imperfections from the surface.  Be gentle.
Neill
Neill said:
Nick,
1) Oil based
2) MDF primed with BIN.
3) RO150FEQ with soft pad in random orbit mode at a low speed (around 2, with the CT set pretty much right on turtle)
For the most part, I don't think I'm oversanding. I get nice even paint removal (as long as I don't accidentally tip the sander)...I'm happy with that aspect of it. I'm just getting frustrated because it seems that to get rid of ALL the tiny little dents that dry in the finish it seems like I'm exposing a lot of primer. I think I'm going to try to concept of several coats with light sanding in between, then sand totally smooth and see where I'm at. I do have to do a least some minor sanding between coats...otherwise I'm leaving trash (dust, etc) in the finish. I don't have a finishing room or anything like that yet, so this is all getting done right in the shop.
I'm wanting a super smooth glossy surface to result, which I realize is way overkill for this project (Clearvue DC), but we're using it as practice with the various techniques involved.
[scared] Man, I wouldn't DARE to use the Rotex on a fresh coat of paint.  [blink]
I would always sand by hand.
Maybe, if you absolutely must use a machine, use an RTS400 or a DTS400 with 320+ grit. But not the Rotex. That's crazy. That completely nullifies your work.
I also think you're trying to achieve something in the wrong way. It seems you're dead set on polishing your way to shininess like you would with staining. But normal gloss paint, if it's of good quality, should have a high glossy shine of itself. No need for further steps. Only thing to improve on the gloss would be to apply a layer of clear lacquer.
I also get the feeling your trying to get a result that's almost impossible to realise by hand. If you really want it to be a shiny spotless mirror, you'd better make a professional spray paint job out of it.
Can you help me understand why? I'm not sure I understand why the Rotex nullifies my work...the whole reason I was okay with spending $500 on a sander was that it is supposed to have the ability to be aggressive and gentle in one package. The Rotex seems to do the job just fine...not very aggressive at all at the low speed in RO mode. I understand that 220 grit might be a little low, I just haven't felt like buying more sandpaper just quite yet and thats the highest grit I have.
When the paint dries, it does have a high glossy shine. But it is not anywhere close to smooth. I figured that I should be able to get it smooth and bring it back to shiny through sanding/polishing...the problem I'm facing is that by the time its totally smooth, I've sanded through the paint in spots to get neighboring spots smooth. I've gotten better coverage with each coat, but its just taking forever. I realize that the ideal way to do this would be spraying, but I don't want to invest in decent spray equipment and set up a booth (and I don't want to waste money on something cheap just for this job). Plus this is a good learning experience for me...I'm really starting to get a good feel for the RO150. If I can get to the point where after sanding to smooth, I've still got full coverage and I can then take it up to 4000 grit with Platin2, I think I'll be happy with the finish.
Nick, I'm no finish expert but I happen to agree with Alex, I think you're going about the wrong way. I'd try this, put on a two coats of paint, I wouldn't sand between coats. After the paint has sufficient time to dry I'd go for lacquer and polish that. A lot of light coats of lacquer, let it dry for a couple of weeks then polish. It would have been better to skip the primer/paint and start with a colored lacquer.
I didn't follow all of your earlier threads so I don't know if anyone already posted this but you don't have to spend a lot money to get into the spraying game. Earlex makes some nice low end sprayers, you can start with the Earlex 3000 for around $140 USD. Perfect sprayer to learn the ropes on, when you outgrow it sell and move on to a better sprayer.
Nick,
I used to work for a guy who used to say "It was a great operation but the patient died".  I am sure you get the idea of this.
You say that you are not "oversanding".  Well, I am not sure what you ARE doing then when you are getting down to your primer and / or raw materials.  The problem is the 220 grit in concert with the Rotex.  Yes, the Rotex is a great sander but if you read all the reviews, it is not a finish sander.  To say that you bought it because it can be aggressive and also benign is true.  The issue is that "aggressive" and "benign" are relative terms, not absolute terms.  I buffed out some semi-gloss paint with my Rotex (125) and Platin.  It looked like gloss+ when I got done.
I agree with Alex.  If you insist on machine sanding, go with one of the smaller sanders.  I understand completely the financial aspect of buying another sander and the abrasives, not cheap.  That is why I suggested to you in my other post that you manually sand using sanding sponges or abrasive pads or steel wool.
I am not so sure about paint applications, but what about rubbing your finish out with steel wool, paraffin oil, pumice stone and rottenstone?  Works great for me with shellacs and other hard finishes.  Maybe someone else can address this question.
Kind of funny when you sand final finishes.  The instructions say finish, sand, finish, sand...  Well, how do you ever stop?
Nick, I sincerely hope you figure it out.
Neill
Sorry for all my ignorance on this...I am new to this...  [embarassed]
I'm honestly not really sure what to do at this point. I'm half tempted to get the Earlex Brice referred to...looks like you can get it at Sears of all places. I wasn't aware that any of the super cheap HVLP setups like that actually worked well. If I had the sprayer, what would be the best paint to use? The only thing I've ever sprayed in the past was automotive paint (and that was quite some time ago).
Sure I can help you understand why Nick. You know, the price of the Rotex doesn't mean anything in this case. Even if you take the most expensive sander of the world, which is your own hand, then it's possible to sand right through the fresh paint very easily. You have to realise, the layer of paint that's on the surface is very thin. When spraying cars in the family body shop, we generally applied a layer of 60 to 80 microns. Now if you paint wood with a brush or a roller, the layer is just marginally thicker, around 100 to 120 microns. 100 micron is 1/10th of a millimeter, or 1/254th of an inch. I mean, that's REALLY thin.
Now, no matter how good the Rotex is or not, that thin layer of paint is very fragile. Also because it isn't totally hardened yet. For fresh paint to harden out 100% can take 2 to 6 months, depending on the type of paint and the thickness. Putting the Rotex on that is like using a harvester to mow your lawn. You yourself said that once you get it smooth you're back to the primer again. It really is that easy to sand through fresh paint. Even by hand you have to be careful.
Another impression I get, is that you seem to think that the process of painting works just like the process of staining. The way you describe your approach to getting a good glossy finish is exactly the way I read here on the FOG how people stain their furniture and then do various sanding/polishing stages to work to a high gloss.
But that's completely wrong. Staining/finishing and painting are two different ball games. The stain is even thinner than paint and is designed to get sucked into the wood. This way the top layer of wood becomes permeated with the stain. When you start sanding it, you sand stain+wood at the same time. With paint, you don't do this. Paint doesn't permeate the wood. Or I'd better say, it's not supposed to. That's why you always have to apply a coat of primer first.
The primer is basically designed to do three things:
1 - Stop the suction of the wood. The thinner elements of the primer get sucked into the wood so that all the pores become completely saturated and won't suck any real paint in anymore.
2 - To fill out the wood grain. The thicker elements in the primer build a filling layer of material that lies ON the wood and even it out.
3 - To provide a layer with a good surface so that the real paint will attach securely.
Once you have a good layer of primer only then will you apply the real paint. The real paint doesn't even touch the wood. Just for fun, you should try out painting a small piece of wood with the real paint WITHOUT a layer of primer to see what the effect is. You'll see your paint get's sucked in to the point where it almost completely vanishes.
So let me recap, with staining you sand stain+wood. With paint though, you sand only the paint itself. Not the wood. Now as for the Rotex, it's more designed with the woodworker in mind (as all Festools) than the painter. It can assist you very well during the whole staining process, but not with painting because it's simply to strong and heavy for the fragile layer of paint. And that's not the fault of the Rotex. Almost any sander is. I never sand with a machine after the final layer of primer. Only by hand. And the only reason I sand at that point is to get rid of the last height differences and to roughen it up a little to get the best attachment for the final layer of paint.
Unfortunately, that's the nature of using a brush or a roller. It doesn't get no where near as smooth as a spray job.
When paint dries, it's not completely homogeneous. The heavier elements sink to the bottom and the lighter go to the surface. Now 'sinking' isn't the correct word because it doesn't rely on gravity but on molecular forces. But I hope you get my drift. The heavier pigments in the paint form the inner part of the layer and the lighter parts form the outer layer that gives the nice glossy shine. All you do when you start to sand that, is that you remove the shiny layer. All your sanding and polishing afterwards will not restore the shine as good as it originally was. Normal paint is not meant to be polished.
The best way to do this is to apply a layer of clear lacquer. On cars, we always used to do this. Without it the car wouldn't shine half as much as with it. We also sprayed furniture, and we also always finished with a clear lacquer. Polishing the layer of lacquer is perfectly possible. You can apply as much layers of lacquer as you want and polish it as much as you want. Just make sure you don't go through it and damage the paint underneath.
Reading this all back I think I could have worded it shorter, but hey, a little bit of background info is never bad I think.  [cool]
Alex,
Thank you! Great job.  Very thorough.  I think we all benefit from your knowledgeable posts.
Neill
Good explanation Alex.
Nick, I've never tried to polish paint and as Alex pointed out I don't know if it will work. Lacquer on the other hand will melt into itself with every coat becoming one completely homogeneous layer of finish. This allows you to to polish it to high shine. You use a fair number of coats of lacquer so you have a thick coat that you can sand and polish perfectly smooth without burning through the finish. You need to wait a couple of weeks or more to allow the lacquer to harden (not cure, that can take months).
Now, inexpensive sprayers, I'm no expert on spraying systems so don't take my advice as gospel. I think a sprayer will give you better results than rolling paint in your application. But it's not going to give you the polished glossy look, not even with the most expensive spraying system will this happen so don't go into it with this expectation if you decide to go forward with a spraying system. An inexpensive sprayer isn't going make you an expert finisher, trust me, I'm living proof. There is a learning process involved. It takes time to learn how to spray, thin your finish and work with different materials and finishes. Now I want to make it clear I don't have the Earlex so I can't comment on it from first hand experience. It is well though of given its low price. At $140 it's hard to go wrong as long as you go in with reasonable expectations and a willingness to learn.
Are you sanding the paint to make the thing smooth and flat
or simply to get rid of the texture in the paint?
It may be that you didn't get the thing flat and smooth enough
in the prime stage. I think we both posted in another thread about
getting a glossy finish. On my cabinet I ended up applying nearly
a gallon of BIN shellac based primer and probably sanded most
of it off to get the thing really flat and smooth. Final grit was 400
(on ES 125) and top coated with spray paint. The spray paint
(Rustoleum X2 Glsoo white) had a texture that I decided I had to accept.
I'd say freekin fantastic! Thanks Alex...I never made the connection that a paint finish was not homogeneous. I understood that the layer of paint was thin, but always thought it was homogeneous throughout...with that understanding I thought I could lay on layer after layer, building it up to the point that I could sand it smooth, then polish it to get the sanding scratches back out, bringing it back to shiny. Your explination sort of changes the entire outlook on this little project...at this point I'm thinking the "ideal" way for me to give this a shot would be to spray a couple of coats of paint on (spraying to try to ensure as clean a finish as possible), then get some lacquer on it like Brice is suggesting.
Another idea would be to use an automotive type finish system (like PPG's Deltron or something similar) as the clearcoat is specifically designed to adhere to the basecoat. Plus you can abrade these (with fine grit, 1200-2000) after only a day. Not sure how expensive these types of finishes are now-a-days, but might be worth a look.
Okay, so a little follow up is in order. I got the rest of my Brilliant paper and Platin assort pack Friday, so now I have grits from 180-4000. So I'm well prepared for when I get to do a project with stain :) Since I had the materials necessary, I decided to take 10 minutes and work one of the pieces up to 4000 grit to see what it would look like. And just as Alex and Brice said, it sucked. Pretty mediocre.
So, went hunting for the Earlex sprayer Brice mentioned. Sometimes living in a small town is really obnoxious. Couldn't find it anywhere...given that Sears, Lowes, and Ace are all listed on Earlex's site, I didn't think it would be a big deal. I was wrong. So it looks like I'll have to order it online. I'm going to go by my local woodworking place today, but not expecting them to have something this entry level...most of their business is with professionals.
As for the paint itself, it looks like I can get enough paint+lacquer to do what I need to do for about $40-$50. For PPG's cheaper system (Shop-line), it would cost me about $80. I'll probably end up forking over the little bit of extra cash to get the PPG system as it'll be dry and ready to polish 24 hours after spraying...Tanya got onto me a bit this weekend for taking so long to do this little project. I tried to tell her I'm learning a lot!!
