I've finally started working with my parallel guides, watched all the videos on it, gone to training, read a lot of the threads, etc. I tried to calibrate them a few times before and got close enough, but never quite perfect. I gave it another try today to less than 0.5mm before I noticed a little detail on mine. I realize these scales are just stickons, but note that the scale for one of them is 55mm from the end and the other is 60mm. My guide extensions are about 1mm difference between the two of them, well within range of the adjustment screws.
Is this much offset (5mm) normal on the longer guides?
[attachimg=#]
Thanks much for help.
[attachimg=#]
