Wonderwino
- Apr 5, 2008
I have tried to address both major complaints about the parallel guides with one simple improvement. I have always found it a little difficult to match the stop to the scale when setting up cuts. Then, if the guide is not supported by a table, it tends to sag and cause slight errors when cutting.
My fix is a rotating 1/4" thick acrylic tab with a line to help set the stop to the scale. This is the first attempt, so it is a little crude. I think the next try, I will simply scratch a line on the bottom of the tab, rather than cutting a shallow grove and filling it with red enamel by Revlon.
I cut the tab 20mm wide and put the line in the center. I then centered the hole for the mounting screw on the projection of the pointer on the guide stop. Keep in mind that the stop is actually beveled, so you will have to shim it on the drill press to get a hole that is verticle to the horozontal axis. I drilled and tapped for a 3/4" long 8-32 stainless steel screw. I drilled the tab on center to accomodate the screw and attached it with the hardwae listed below.
The first picture shows the tab in the gauging position with the too-thick red line over the pointer. The second shows the tab in the supporting position. The third shows the fastener section with a metal washer, followed by a rubber washer, followed by the tab, another metal washer and a wavy washer to create friction.
Copyright 2010, Alex Leslie, Wonderwino Engineering.
