darbo
- Jun 18, 2010
I tried out the parallel guides over the weekend. I used them to rip 8' birch ply to make a long fence to support the Kreg stops system for my Kapex. I got decent results from the guides, but was disappointed that my boards ended up just a hair out of parallel over the 8' long cut. Try as I might to perfectly calibrate the rails to each other I just couldn't get them perfect. I think part of my problem is the (relatively) huge 1 mm wide expanse between the arrow on the stops and the measure, which makes it very hard to know if you've aligned the two stops perfectly in exactly the same way. And it's not just the space between stops and measuring line that is problematic; I also dislike the pointer itself on the stops. Why can't the stops have a fine printed/embossed black line matching the lines on the guides measuring rule instead of an open ended embossed arrow? I can try to paint my own line on, but I'd rather Festool do it at the factory. After failing to get perfect results I set the not-so-parallel guides aside and went back to just placing tick marks at both of the boards...which did produce perfect results.
Anyway, all that to ask a few parallel guide questions:
I'm sure I'll get the hang of the guides with continued use, but I also am sure that Festool could have done a much better job of making them easier to get perfectly aligned. Such as designing the tool without gaps between stops and measurring line. Seriously, who uses a tape measure and places their tick marks a full 1 mm or 1/16" away from the measuring tape? That's not a recipe for accuracy, is it? I hope the guides will be re-designed and improved to get that fixed.
- What is your preferred method for perfectly calibrating the main parallel guides and ensuring that the stops are perfectly aligned with each other? I was amazed that mine came a whole 1 mm out of alignment out of the box. I calibrated them and was certain I had done a careful job of perfectly aligning them, but my results told a different story.
- What improvements have you made to your parallel guides to overcome the product's weakness of that gap between the measure and the stop? I saw the example of someone attaching keys to their stops to bridge that gap (may have been on another forum), but household keys are about as precise as my thumb. I would love to see a mod employing a bit finer sort of alignment arrow. I wish that tool mfgrs would start doing what Incra does with their ribbed tracks (and lead screws) that allow stops to click to known increments (1/32" or 1/2 mm), while also providing micro-adjusting for obtaining finer results.
- Have any of you applied an imperial measuring tape over the product's metric one? I'm not opposed to metric and, thanks to my iPhones handy conversion app, making conversions is very easy. But if my design calls for a 15 7/8" cut then I prefer to make a 15 7/8" cut and not attempt to make a 403.225 mm cut. Anyway, slapping an imperial tape over the supplied metric one seems like it should be easy enough, so I'm interested to learn if any of you have tried it.
