NuggyBuggy said:@jeromem, why would having the sides tight to the piece be a problem ? Also, as far as I could tell, none of the mods that you did would seem to increase the accuracy, am I wrong ?
First point having the sides tight to the piece when the stock is long can binding so the end stops do not make complete contact on both sides. This is because the guides do not need to be at an exact 90degrees to the rail and getting them to that is not so easy. It is possible to get one guide to 90degrees and so use it an an angle guide but then the adjustment screws need to be quite tight so making removal and length adjustments less easy
There is a degree of slop in the clamping fitting that has no effect on the accuracy of repeat cuts of exactly the same width but different lengths
[attachthumb=1]
here I am cutting the lids off my "2x" systainer boxes
[attachthumb=2]
and as you can see it is accurate enough on 30cm and 80cm lengths to cut the tops of boxes
AFIK there is no modification that increases the accuracy of the guides themselves as they are very accurate. However that may be just semantics the modification that I made http://www.flickr.com/photos/nui-jerome/4496012364/#in/set-72157623650184949/ and the one that Wonderwino in his post http://festoolownersgroup.com/festool-tools-accessories/parallel-guide-improvements/ both make accurate setting easer. With mine you line up the back of the key with one of the cast angles with Wonderwino's you have a wider mark so could use either side.
Here is another view
