jobsworth said:I wonder if they make a festool bib [crying]
...only any good with green catsup !
I will bring some wet wipes to the D&M Show next year or get some other FOGgers to hose you down after every meal.
Peter Parfitt said:jobsworth said:I wonder if they make a festool bib [crying]
jobsworth said:Hey bud you buying?? [big grin] Nothing goes better then a cold beer and a hotdog with lots of catsup and mustard on it...
I like them so much, I take a little bit with with me to remind me how good it was.(hehehehehehehe)
leer said:jobsworth said:Hey bud you buying?? [big grin] Nothing goes better then a cold beer and a hotdog with lots of catsup and mustard on it...
At the risk of starting another war of words ...
Everyone knows hot dogs should NEVER have catsup on them. It is mustard. Relish and onions are permissable, and possibly a few other condiments. [wink]
Now, to change the topic quickly ...
Peter, I got some Parf Dogs before Christmas from Lee Valley. Absolutely fantastic. Firt my custom MFT-style top perfectly. I used the Qwas Dogs for reference when milling, as my benchmark for fit. The Parf Dogs were "spot on". (Isn't that the appropriate terminology for describing them? [smile])
leer said:Now, to change the topic quickly ...
PreferrablyWood said:After watching your video on the Parf dogs/bench dogs, I see I should get 2 pairs of each so I'm going to try and change my order.
I notice that you (Peter Parfitt) say in the video that with the dogs you don't really need the extra hardware on the full version of the MFT 3, and just to go with the basic, but I feel that at least for newbie's like me being introduced to the MFT 3 komplete gives added confidence when first getting to know the system. These new tools will doubtless lead me on to find new and more efficient ways of working. I have used my own improvised track system in the past, so what attracted me to the MFT 3 was the the guide rail setup with the mitre which I had envisioned would turn my TS 75 into a mitre saw with a very wide cutting length very respectable 70mm cutting depth..
I'm sure the short rail guide the fence and the stop will be nice to use so those things alone add up to the difference in price between the MFT 3 and the MFT 3 basic..
I do like the your ideas of going for simplicity in setup. If you just want to take a few elements out when doing a few basic processes.
To sum up I'm really glad I went with the Parf Dogs, Bench dogs, which add a new dimension to Festools system and am very pleased they are available at a competitive price on this side of the pond!
VirtuaLogic said:I don't know if someone else has already brought this up, but after working for a couple of days with the tall Parf Dogs I have a couple of suggestions. When butting the guide rail against the Parf Dogs, if the stock is not thick enough, the TS55 interferes with the Parf dogs when plunged. This can be circumvented by putting a spacer in between the Parf dogs and the rail. However, a homemade spacer is not as accurate as the precision machined dogs. I thought of 2 solutions:
- A set of stainless steel rings, precision machined to fit over the Parf Dogs, to widen the base of the dogs while keeping the precision of the machined steel
- A set of Parf Dogs that are less tall
Or maybe a combination of the above; a set of less tall Parf Dogs with "integrated" extra wide base.
Just my 2 cents.
Cheers, Alex.
VirtuaLogic said:Hi Peter,
I get the interference all the time, because my cutting station is only about 60cm deep.
I've found the interference to be there when cutting thin stock like sheet plywood. And I've also found a solution: flip the lower Parf dog over and insert the long end into the table. The other, shorter end is the same diameter as the long end and works perfectly to butt the guide rail to with no interference.
Another solution would be to rotate the working orientation 90 degrees. This allows for more space between the lower do and te work piece.
Cheers, Alex
