Slappy
- Aug 21, 2013
might be using the wrong term
but these are what I use
but I use the 3 flute model I'll post the bosch p/n in the morning for the 3 flute model I've used both the 1/2" & the 1/4" shank
http://www.amazon.com/Bosch-85266M-Diameter-Laminate-Bearing/product-reviews/B000GY9WCC/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
I'm Not actually drilling the hole I'm cutting the hole out with a bearing loaded trim cut router bit , the 3 flute give a fine cut surface , the bearing actually copies the holes & cuts an exact copy of the template on the new board .
