joiner1970
- Jun 13, 2007
Using my pdc drill today on a job and had to use a 32mm bit to drill through a front door. Set it to 2 thinking it would easily do it but the torque kicked in. Dropped to 1 and it went through no problem but as I put the drill away I noticed it didn't seem to be spinning as fast as it was. I upped the speed to 4 and it still didn't sound right. First thoughts were that I had overloaded it and it had gone into some sort of safety mode. I removed the battery and refitted it and still it sounded slow. Then I noticed the torque switch wasn't on the drill mode. As soon as switched the torque off it spun as per normal.
So that leads me to ask does the torque switch adjust the speed as well as setting the torque. I'm used to the usual drills by other brands where it's mechanical torque with the usual noise. These festool drills bleep .
I run the drill on several torque settings and free running it did look like it affected the speed.
