Bigchasbroon
- Apr 12, 2013
I find the speed selector on my PDC18 quadrive really stiff. It takes 2 thumbs to change it. The drill/ hammer switch is really smooth. Anyone else have this issue?
Bigchasbroon said:I find the speed selector on my PDC18 quadrive really stiff. It takes 2 thumbs to change it. The drill/ hammer switch is really smooth. Anyone else have this issue?
jonny round boy said:More annoying (on mine at least) is the direction switch. Like most Festool drills, I assume this is not a mechanical or electrical switch, but electronic, relying on a sensor to detect the position. When it's in forward, it only takes a slight touch on the switch to knock it into reverse by accident. Even if the switch moves only 0.5mm, that's enough to put the drill in reverse.
It's a real problem when you're working in a confined space, or need to pass the drill from one hand to another, or need to hold it in a non-conventional way. [sad]
