After years of painting mat board bevels freehand, brush applying finish on edgebanding is a breeze.
It takes two passes to paint one edge. Hmm. I was going to try to describe the technique. I’ll try making a photo instead. It is pretty fast and easy once you have the technique down pat.
I’ll try a photo tomorrow.
As promised, but with poorer photos than I had hoped. I found it extremely difficult to hold the camera with my left hand and perform the brush work with my right hand while viewing through the camera’s screen. Enough for my apologies.
The first image shows the artists’ brush I use. It is slightly narrower than the width of the board, and is a flat brush. Also note the round shaft. A round shaft is much easier to rotate to the preferred angle.
The second photo shows the hand position. Note that I have my fingers resting on the side of the board. The side of the board is, in effect, a track that guides my hand (and brush) in a perfectly straight line.
When I am painting an edge of a board, I watch one side only. I keep my eye on the side of the board that is further from my hand. I will go back on a second pass with my hand on the other side of the board. This gives me double coverage in the center, so I only need to keep my eye one side.
The video (embarrassing quality) shows me drawing my hand along the edge. There is a “sweet spot” in the speed I draw my hand along that edge. If I go too slow, the brush does not follow a nice straight line. If I go to fast, I lose control of the brush. You will have to determine your “sweet spot” speed.
Also, the amount you load the brush up with paint is important. If you have enough paint on the brush that the instant you rest the brush on the surface it pools paint on the surface, that is too much. You will than pull the brush through the pooled paint and it will go over the side.
Initially you may have to make two passes in each direction as it is preferred that you have slightly less paint than ideal on the brush than to have too much paint on the brush.
Since you are working with prefinished plywood, a wet rag, followed by a dry rag will remove any excess that goes over the edge.
If I can recruit a helper, I may re-shoot these pictures and video.
I have used grain filler on the edges of melamine clad particle board and followed with contrasting color paint. I like acrylic paint for color and topcoat with a clear acrylic coat for durability. General Finishes “Milk Paint” (a modern acrylic paint that resembles milk paint when dry) brushes out nicely and is my preferred paint for this type of work.
Close up, brush.
Close up, hand position.
Video.
