Pica/Profiler Legends Precision Set
Ultimate Tools Marketing
Festool Dealer
Burnaby, BC
Note: Orders for this item may take 1-2 weeks to arrive at our store.
The Pica/Profiler Legends Precision Set combines the craftsmanship of Profiler+ with the innovation of Pica to deliver unmatched precision in every scribe. At its core is the Profiler+ tool, trusted by tradespeople and DIYers to create accurate scribe lines for neat trim work.
One end features a pair of stainless steel bearings that glide smoothly over anything - even rough materials. The bearings also have a hidden function: a compass point for drawing circles and arcs.
The other end has a fine precision tip for complex profiles such as mouldings. It's thin, yet broad shape is perfectly shaped for accurate scribing.
Crafted in Britain from premium materials, the Profiler+ is built for durability and everyday reliability. Paired with Pica's Dry Longlife Automatic 2.8mm Pencil 3030 and Pica's Multi-Use Water Soluble Refill Set 4020, this set gives you the flexibility to work with any surface and any marking style.
Whether you’re in the workshop or on site, the Pica Profiler Legends Precision Set is designed to help you achieve professional results with ease.
Shop the Set
The Pica/Profiler Legends Precision Set is the ultimate combo for flawless scribing: bearings that glide, a precision tip for detailed profiles, and Pica’s legendary marking tools.
Order now and take your trim work to the next level.
Please note that orders for this item may take 1-2 weeks to arrive at our store.
Order Your Set Today
