- Jan 22, 2007
Order your Woodpeckers OneTIME Tools online from Tool Nut and get free shipping on all orders over $40. Order deadline is JUNE 15th.
A Pocket-Sized Beam Compass For The 21st Century. Woodpeckers Pocket Compass makes significant improvements on the traditional, larger beam compass familiar to woodworkers. Rather than fixing trammel points on a wood stick, our compass uses a pair of precision-machined, telescoping body parts that lock to your desired dimension with a twist of a knurled head screw.
Accurate, Easy Set Up. Pocket Compass features precision, laser engraved scales (Imperial and metric) on one half of the body that are easy to set to the sliding hairline mark on the other body part. To draw your circle or arc, simply insert the center pin on one end and a mechanical pencil in the tapered hole on the other. Swing the compass and you’re done! Our compass also has additional precision-machined pencil placement holes to conveniently increase the compass setting diameter in 1” increments.
You Won’t Get Stuck With Our Pocket Compass. Another point about our new compass design is– the point! Unlike the common divider-style compass with its pin-sharp centering point, you can tote our Pocket Compass in your shop apron without feeling like a pincushion.
When not in use, the stainless steel centering point securely stores in the compass body keeping you out of harm’s way.
Two Compass Sizes, Get Both! We make our quality Pocket Compass in two sizes for drawing a wide range of circle diameters. Original Pocket Compass is compact (about the size of a disposable lighter).
It can strike circles from 1” to 7” and is perfect for tucking into your shop apron. The new, larger sized Pocket Compass XL tackles circles and arcs from 2” all the way up to 21” in diameter.
When you order both sizes, your pair of Pocket Compasses will come in a protective molded case with a custom-cut foam interior including an American made Woodpeckers .9mm mechanical pencil, a 12 pack of pencil lead and a 4 pack of erasers.
