Linbro said:Seth, isn't that spot for the dust collection adapter?
I'm pretty sure the heads come in plastic tubes, so would be fine just floating in the box.
Also Seth - do you know if the bigger fence fits in the sys?
Linbro said:OK, thanks Seth.
The fence that comes with it is 'ok', but the bigger one is much nicer.
SRSemenza said:There is actually a spot for one extra cutter head. It stands on end and layers on top of the edge guide spot.
If it were bumped up to a Midi - Sys there would be room for several.
Of course the bench unit won't fit either , but it will fit in a separate Sys-III.
Gwerner said:SRSemenza said:There is actually a spot for one extra cutter head. It stands on end and layers on top of the edge guide spot.
Thanks Seth, just to confirm, I would need a separate Sys 3 for the bench unit and bench unit fence?
Yup that's what I did was buy a separate sustainer for the fence and bench unit.Gwerner said:SRSemenza said:There is actually a spot for one extra cutter head. It stands on end and layers on top of the edge guide spot.
