Planex coming in soon, what is a must to buy with it.
Jaybolishes
Hi guys, I have a lot of drywalling to do.  I am ready to start putting up rock in a building I am turning from an old carriage house into a single family living unit.  What is a must to buy with the Planex.  I ordered the blast gate and 80 100  150 grit paper. I heard it  doesn't come with the Planex hose, but i think that was wrong info. Do you find the regular 36 mm hose to be a problem staying on?  If you guys who have used the Planex a lot can give me a heads up on what I should get up front, I'd hate to find out through trial and Error.
 Thanks guys, any tips would be greatly appreciated.
And those who hire drywallers, that's cool, I like to work on my apartments and home all by myself, great therapy.
Is it a new version of planes or is USA so far behind on festool products?? Denmark has been selling Planex for years..???
Jaybolishes said:
Hi guys, I have a lot of drywalling to do.  I am ready to start putting up rock in a building I am turning from an old carriage house into a single family living unit.  What is a must to buy with the Planex.  I ordered the blast gate and 80 100  150 grit paper. It doesn't come with the Planex hose.  Do you find the regular 36 mm hose to be a problem staying on?  If you guys who have used the Planex a lot can give me a heads up on what I should get up front, I'd hate to find out through trial and
Error.
This is a complete wish, but could I swap the 36mm hose for the planex hose when I pick it up.  I think getting the Planex without the Planex hose is a little ridiculous, but I'm no penny pincher and what everything I need up front.  Thanks guys, any tips would be greatly appreciated.
I can't speak from experience, being an American dealer, so maybe one of our Euro or Aussie friends can chime in, but I know the connection of the Planex hose to the Planex with the little clippy-poo (yes, clippy-poo) is certainly a response, in one form of another, to an issue that plagues the Porter Cable Drywall Sander.  That tool is prone to having the hose fall off, mid sanding.  Imagine the mess and frustration.
I'd definitely recommend the Planex hose along with a CT 36 AC.  If you don't want the AC, at least get a Festool vac and swap it out at your dealer of choice within 30 days if you feel the vac wont be up to snuff considering it'll be lacking the auto clean function.
Sanding overhead?  I'd highly recommend the harness.  Awesome accessory and allows for all day sanding.  Sure, it's neat that the sander can literally suck itself to the ceiling but the quality of sanding you'll get at that high of a suction and still supporting it in one way of another with your own strength will never compare to ease of use with the harness.
Be sure you're good to go on paper.
Sean, are you guys gonna have the harness next time i come down? For the money im gonna eventually spend on this item, i would like to try it on first. One of the things i like about buying a third DC is that i can keep two in the shop, one per bay and not have to move them around much. Plus the RO150 is getting a work out as my primary drywall sander, Eric
My planex came in today!  Sorry i modified my first post to not confuse anyone like i was.  The ac 36 vac is back ordered a week or so, but can't wait until that comes in.  I apologize,  the ac 36 vac definately does come with the hose.  I called another dealer who had the vac in stock and the dealer affirmed that the planex hose does come with it here in the usa.  I just got home, I'm going to try the planex for the first time hooked up to my ridgid vac and see how it does on my popcorn ceiling. I'll be posting a thorough review after I get my back ordered ac36. But I'll chime in with a few thoughts on the first test drive.
Careful with that popcorn, might want to test it for asbestos before you try doing anything with it connected to a SHOP VAC :)
(Depending on how old the popcorn ceiling is)
Thank you for the warning, my house was built in 1986, so I should be ok right.  That's a great point to consider.
Eric, always in stock!
Peter, didnt see it in the shop when i was there. I was too busy hanging with the guys. Will have to get the full tour next time we are down, Eric
Your going to love the planex and it's a must with the CT 36 AC. Alway keep the head moving because it can take off Sheetrock fast. If your ceiling is over 8' the harness is a must. I found going with a 220 grit for the final sand works the best for a smooth finish. It's a beautiful machine, enjoy!
Johncarlo
My experience to date is limited to one wall and some popcorn(y) ceiling.
The Planex is a pretty phenomenal machine when dialed in.
I started this wall in our house and it took a couple of minutes to figure out what grit paper to use and how to set the speed of the head and suction. After a short time, it was easy.
The objective here was to remove the texture that is a sort of a "drag" effect.
[attachthumb=#1]
I had previously only played with it a few square feet of wall and a little ceiling. I did the top and bottom of this wall in about 15 minutes. While watching me do it, my wife wanted in on the action and she did the middle part. It took her about a minute or two to get the hang of it. Incidentally, she's a 115 pound health care provider... For the middle part that she did, I took off the extension that comes with the unit.
[attachthumb=#2]
I plan to remove this texture and the popcorn from my ceilings all throughout the house as part of an ongoing remodel. I know I could use other methods but this is easy and I like the result as opposed to skimming over or, in the case of the popcorn, using the wet and scrape method.
My experience with the abrasives is that the typical 120-180 or so Brilliant 2 might be good for new work. For taking down old chunky stuff like this, I'd look at 80 Brilliant or some Safir.
If you're doing the ceilings or a lot of high walls, the harness kit is a very good deal. You get the harness and the pole that parallels the Planex as a handle in a Maxi Systainer for $200. The Maxi alone costs more than half of that...
The CT 36 AC is a nice addition to the set as is the  special hose and blast gate, which makes it work better on the back blasts. I did this wall with my CT 26 and had no problems but if I spent all day doing this stuff repeatedly, I'd optimize the situation.
That's my current observation. I'll have more to add to it soon... I was building sandpaper shelving when I took a break and noticed this thread.
