The PLANEX is deisnged for sanding primed drywall constructions, ceilings and walls in internal and external applications as well as removing carpet residue, coats of paint, coverings, adhesives and loose plaster.
Shane Holland said:I would not advise using the Planex for anything other than its intended use: drywall. One of the things that will void the warranty is misuse. Also, not using a tool as prescribed by the manual.
From the manual, page 10, Intended Use:
Please read the intended use sentence in the manual again and break the logical structure of it correctly:Festool USA said:I would not advise using the Planex for anything other than its intended use: drywall. One of the things that will void the warranty is misuse. Also, not using a tool as prescribed by the manual.
The PLANEX is desinged for sanding primed drywall constructions, ceilings and walls in internal and external applications as well as removing carpet residue, coats of paint, coverings, adhesives and loose plaster.
The PLANEX is desinged for [somejobs] as well as removing carpet residue, coats of paint, coverings, adhesives and loose plaster.
The PLANEX is desinged for [somejobs] [and] removing carpet residue, coats of paint, coverings, adhesives and loose plaster.
The PLANEX is desinged for removing carpet residue, coats of paint, coverings, adhesives and loose plaster.
