Please Consider These to be PSA's
Peter, I hoope you did not damage the blade  [scratch chin]
Actually, i am glad no serous damage to your hand as well.
To those who mention it is good to let the wound bleed for a little while, I agree very heartily.  I have always done just that.  If the wound is pumping blood in spurts, direct pressure to wound or to the artery at a point closer to the heart than the wound as quickly as possible.  Just plain dripping, let it bleed for a while.  I have smashed fingers any number of ways while working with different types of machinery, knives and other cutting tools.  If it ain't bleeding profusely, I will whirl my hand just to get the blood flowing to clean out any debris and bacteria from the surface.  ::) [unsure] 8)
Tinker
Tim Raleigh said:
Peter Halle said:
I am fine.  The finger that took the brunt was the one that I had cut the tip off until it was dangling back in 2001.
What exactly were you doing?
Can you describe where your fingers were and what blade etc. The reason I ask is I often cut small pieces of wood with the jigsaw and my fingers are close to the blade, but the jigsaw is always on the underside and my fingers are within view of the travelling blade with my thumb resting on or against the jigsaw shoe. Not to say that the blade won't ever hit a soft spot and veer off and hit my fingers...
While I appreciate the message, and rereading this thread several times I am struggling to figure out how you cut yourself. Yes I know where and what you did it with, but exactly how you did it i.e. where your fingers were and where the saw was etc. would help me to visualize this error and hopefully avoid it.
Thanks again.
Tim
Tim,
I have never been afraid to tell on myself about stupid things I've done in the hope that my stupidity will prevent someone else from doing it.  So in the light of "Don't be stupid and do this" here goes:
My house is partially torn up from two water leaks and it was time to install the crown molding in the bathroom.  I needed to make a quick jig to hold the crown on the Kapex and I was being lazy and in a rush.  I had already cut out the base of the jig and then just needed a strip to attach to it to act as a crown stop.  Looking at my scraps I saw a piece of the beaded back member lying on the ground.  That would work but at its full width it would obscure the measurement scale once mounted on the Kapex.  So I needed to rip it.  Let's just forget that my MFT was set up as a stand for the Kapex.  Let's forget the fact that I had a sheet of foam and my TS-55 15 feet away.  So I decided to rip the 4 1/4" wide short piece while hand holding it.  It went ok while I had part of it rested on the end of the MFT but as the end came close and it was time to hand hole it for the last bit and it became unbalanced then before I could drop everything my hands came in the danger zone.  My fingers were underneath when it happened with the shifting wood.
I knew I shouldn't have done it but "It was only one cut.  It will be ok."  Dumb me.
Peter...it's only dumb if you don't learn and remember!  Because actually...what you found was [wink] a GREAT way to chew up your finger, so there's a NEW Discovery you made [big grin]
Thanks Peter, I understand. Easily done, glad you are ok.
Tim
  You are certainly not alone in being lazy and in a rush, this is probably something we are all guilty of at some time or another, human nature to take A short cut or two when it comes to a quick job when time is marching on. Thanks for the timely reminder.
It is a lot easier to chop off a finger than to put back on.  I think i have told this on the FOG before, but here is a good place to repeat the warning.
I had damaged a planter in a customer's yard while hurrying around it while mowing.  I told the lady i would repair it.  I had only damaged one leg, but to match the wood turned out to be somewhat difficult.  I decided to replace all four legs.  The repair required that i produce a couple of sliding DT's in the top of each 4/4 leg.  The legs were cedar, so what problem could i have?  Before tackling the "real" legs, i planned to make a couple of practice cuts on one of the off cut pieces.
I started with a 1/2" uncut bit in the router table.  That was easy.  I routed a 3" channel into the piece and just raised the block of wood off of the bit with no problem.  I replaced the straight bit with a large DT bit and plowed into the same groove.  however, once I had plowed the full length of the original dado, intend of raising the wood off the bit, i had to back out of the cut.  There seemed to be a little more resistance than i had expected.  I had done sliding DT's on flat boards to set shelves before with no problem.  This time, I was making a fairly deep cut with a much larged DT bit and the resistance was much greater than I had expected.  To overcome the resistance, as I was holding and pulling the uncut end of the 4x4, I cupped my hand over the cut end to give better pull and to add some control.  all of a sudden, I felt a very slight tickle at the end of one of my fingers.  I guess i knew what was happening as my reaction was instant.  That little tickle did not actually hurt, but my reaction was probably just as quick as if it had been a sharp pain.  I had blood all over the table, the scrap piece i was working on and on me.  I had quite a gash in the end of my finger.
I just patched the finger with a bandaid and several wraps of self sticking gauze tape and went back to work.  A few days later, I was running out of the gauze self sticking tape and went to my druggist for more.  she asked about my wound and i explained that i had tried to stop a whirling router bit with my finger.  By now, the skin was beginning to peel off of the finger.  The lady asked to see what was happening.  i pulled off the bndage and he took one look and told me i needed some professional attention, or i might lose the finger.  since i thought she was talking about professional halp for the finger, and not my head, I did go to my primary doc whereupon he used my arm for a dart board and gave me a piece of paper telling me of some pills to take and sent me right back to the druggist.  Even tho there was never any pain, as I had done the right steps to caring for the wound other than going to the doc in the first place, infection was beginning to set in.  All did end well and the infection was nipped before becoming dangerous to the rest of my appendage and even into my hand, i did change my procedure to cutting those DT's.  It was proven to be much simpler practice to use a slightly smaller DT bit and cut in on one side of the cut and back ut on the other side of the cut.  AND, do not put fingers over the end of the dado for added leverage as I pulled the wood away from the the channel.
So many lessons learned from one tiny mistook. ::)
Tinker
