plexiglas template on the cheap side
FEStastic
HI
Made this in 30 Min's cost me ?5
[attachimg=#]
[attachimg=#]
[attachimg=#]
[attachimg=#]
I  also made  this additional fence
[attachimg=#]
[attachimg=#]
made  small enough to fit with the rest of the 0f1400 attachments
[attachimg=#]
[attachimg=#]
EBay is great for small bits of plastic
I like it.  I'll definitely make that if I can't get a decent old-style edge guide for the 1400.
I also like your Systainer setup.  Did you move the 1400 to a larger Sys and put in a mini for bits?  I'd like to see more about that, too :)
Hello,
          The Systainer 4 is the one it came with. I took out the liner (never could remember where things went )
I went down this path as the plastic was at hand, plus good practice working with anything other then wood. Expand the skills.
I'm looking for a way to adapt the Systainer 4 lid to make a portable router table  or a way to suspend /support the  router ......
I have much love for the mini Systainer,  have one in my Cordless drills Systainer as well.
That is brilliant!
You've inspired me too.
Is the mini-systainer configured for router bits, or did you adapt it too?
Any chance of a peek inside the mini-systainer?
Thanks.
Neal
[thumbs up] Way to go.
Looks like the router has seen some action, judging by the marks on the base.
I have a question though, what kind of screws did you use to join the two parts of plexiglas? I have never had any luck in screwing into plastic, it always cracks or shatters, maybe I tried the wrong type of plastic [doh]
Rob.
Hi
inside the mini is ....
[attachimg=#]
A bit messy bit i know whats there and where to find it, before I stored all my router bits there and zip lock bags in the sys4 for the biscuits and worktop connecters.This was a pain as they rip and fiddly putting everything back at end of job.In there are some other fixings  for making jigs on the fly.  But now I use a separate Systainer 1 for Router bits
[attachimg=#]
Keeps every thing from getting chipped also can see if anythings missing. I need to find a way to store the longer router bits flat, thats why I left the space in the middle.
The jig was assembled with machine screws.
[attachimg=#]
I drilled and tapped the plastic. The key is using sharp drill bits, keep the revs low as the swarf will melt binding the drill bit.
If this happens try and go in reverse or gently heat the plastic and back the drill bit out.
To make the threads I use a cordless and a starter tap as the bevel is guided by the pilot hole.
[attachimg=#]
Drill on low gear, Do a bit as you feel resistance  go in reverse and come out and clear the tap. Keep going until you have the thread depth you need.
You must stop before you reach the thicker non threaded part as this will bind in possibly cracking the plastic or on more ductile plastics the thread will be striped. Practice where it not critical  I do Aluminium the same way. For most setups M6 is good enough any smaller and it becomes fiddly as the tap threads are finer and clog up. Try A bit of oil if the swarf is not moving out easy, but it makes a mess. Try and use Dry PTFE spray.
Hope that helps  [wink]
Thanks for that Festastic. [thumbs up]
Should've thought about machine screws [doh] I just get blind sided by ways to deal with timber [big grin].
Rob.
